Is there a maximum frame rate that can be transmitted when I use the CVMock.vin in combination with the GEV server? Theoretically, I could also select a frame rate that none of your cameras can achieve. Are there any limitations here or are they simply limited by the hardware?
It’s limited by the hardware. You’ll need to push the data through the network so around 100 Mbit/s is the limit.
Great, thank you very much for the quick response.
