Best camera and network board parameters set up
Hi all,
Hope you are doing well.
Since now more than one year did I change my way to acquire camera from an old way to do this with CVB to the stack 3.
I use the new cpp codes with at least 10 differents cameras, from AT C4, C5, C5 SCT and C6 to Dalsa nano color and grey and so on.
I setup some Genicam settings like the scpsp packet size for exemple that help and work well.
For a lot of application, I can see that this kind of basic setup are fine.
But sometime, I need to spend a lot of time trying differents values for my acquisition doesn’t get transfert loss or others problems (currently I geot a C5 no SCT that have some weird line on a packet image like there is an copy error). Or I see on the line directly that we got acquisition delay or miscopy or anything else on the image.
So I was wandering if there is a pdf or a page on the web that explain how Genicam is working, what kind of parameters is available on cameras, which one is important, which one is not, etc. ? And maybe other transfert parameters importants on the network board like Jumbo packet ?
It may be a basic question, but I learn to use genicam on the work and I never get a proper lesson or proper document.
So if you can redirect me or explain me here, I will be gratefull.
Best of luck,
Hi @AxelDosSantosDoAlto ,
have a look at the following link, this should be exactly what you are looking for:
https://help.commonvisionblox.com/NextGen/14.1/md_scripts_main__manuals.html#manuals_hardware_user_guides
That’s all I need, thanks !
Axel
