Cvmgmtd.service super slow shutdown
Hiya guys, i’m having issues with cvmgmtd.service being super slow at shutting down, this is slowing the shutdown time of the system by minutes and I would love to sort that out, does anyone know what the reason for this is and whether there are any fixes in place for this?
● cvmgmtd.service - Common Vision Blox Management Daemon.
   Loaded: loaded (/lib/systemd/system/cvmgmtd.service; enabled; vendor preset: enabled)
   Active: failed (Result: timeout) since Mon 2023-03-13 13:19:09 UTC; 2min 14s ago
 Main PID: 1540 (code=killed, signal=KILL)
Mar 13 03:29:19 xx systemd[1]: Starting Common Vision Blox Management Daemon....
Mar 13 03:29:19 xx systemd[1]: Started Common Vision Blox Management Daemon..
Mar 13 13:17:38 xx systemd[1]: Stopping Common Vision Blox Management Daemon....
Mar 13 13:19:09 xx systemd[1]: cvmgmtd.service: State 'stop-sigterm' timed out. Killing.
Mar 13 13:19:09 xx systemd[1]: cvmgmtd.service: Killing process 1540 (cvmgmtd) with signal SIGKILL.
Mar 13 13:19:09 xx systemd[1]: cvmgmtd.service: Main process exited, code=killed, status=9/KILL
Mar 13 13:19:09 xx systemd[1]: cvmgmtd.service: Failed with result 'timeout'.
Mar 13 13:19:09 xx systemd[1]: Stopped Common Vision Blox Management Daemon..
