CVB not working on certain PCs
Hi @frage12358,
If the camera is working in GenICam Browser, it is most likely, that the configuration of the GenICam driver is erroneous! Please double check if you did it correctly as follows:
grafik
  1. If you see the camera as a green icon, that means it has a proper IP address and is working (You can check that by double clicking it to get some live images)
  2. Click the “Add” button to add it to the list of configured devices
  3. The camera should now appear on the right side. These are the devices, that will later be accessible via the GenICam driver.
  4. Save the configuration.
By the way: the latest version of :cvb: is 13.02 :slight_smile: You can download it here in the Forum’s download section: https://forum.commonvisionblox.com/c/downloads
