With CVB 13.04.005.
After CVB installation, using “CVB Management Console” to add 2 cams:
1st cam: Dalsa Linea gige
2nd cam: ATC5 2040 gige
(I know this app becomes deprecated).
I opened CVB “Image View” and selected “genicam.vin”.
Using grabber properties, I selected cam2.
BIG BUG: Doing this selection, the cams was removed from genicam.ini.
I did the same configuration with “GenIcamBrower” app, and it worked fine.
Hi @Mikael
CVB Management Console will be removed with CVB v14.0.X.
(I.e. Soon).
So we will likely not invest time into this, if the Genicambrowser works for you.
But this is a weird bug, since Image View and the Genicam.vin should not write the Genicam.ini with your use-case.
