Activate TurboDrive
Hi all,
Small question this time. I’m activating TurboDrive the same way as described here (parameter “UseTurboDrive”). After activation, how can I increase the framerate beyond their ‘normal’ limits?
I’m using a Teledyne Dalsa Genie Nano C1280 for this.
Hi Thomes,
just use the normal Std::AcquisitionFrameRate genicam feature. You will not see a change in the limits of that feature. Only the network traffik is reduced. The limits depend on the sensor speed and resolution, not on the use of TD.
Regards
Thanks @dusalf. That’s all I needed to know.
