some days ago I managed to load *avi files and grab frames from it. Unfortunately there is the watermark on the images, is this because I dont have a license for the suite?
Thanks
Thanks
Hi @johmarjac
when using
without a valid license two things will happen:
These things will go away once a license is available for the parts of
that you are using (if they don’t, please contact support). If you want to try out
without being pestered by those license restrictions then please submit a request for a trial license (open the Management Console, go to the License section, select “Node Locked” and click the button “Get Free Trial License”; fill in the form that opens and send the file that’ll be generated to cvblicense@stemmer-imaging.de). Note that trial licenses won’t work on virtual machines.
Thats sad, since I am using CVB on a virtual machine because my main pc needs to have x86 installed. x64 I need for the new software since its going to be x64 and since you cant run both architectures on same machine I used a virtual machine for that… Mhh, is there no work around for that?
Anyways, I think without a license is fine for now.
I am sorry, there is really no way around that particular limitation. We are aware that forcing a user to choose between either Win32 or x64 installation is an annoying limitation and we have ideas how to change this in a major release in the future (this will require breaking changes in the API of the ActiveX controls so this is not going to happen before 14.0).
Hi @illusive
great to hear that there might be worked in future. For now I am pretty sure I dont need a license. As the software is really only for acquiring images, and then saving them to hard disk. If I would require to do image processing on the image then thats of course looking quite different.
Thanks
