Split from another topic:
assuming you have PTP running (set PTP Mode to Automatic) you need to set the Timestamp Modulo Event and the Timestamp Modulo Event Start Time according to your framerate.
Once this is done set the Trigger Selector to Single Frame Trigger and set the Trigger Source to Timestamp Modulo Event. Now after enabling the trigger and starting the acquisition you get the framerate according to your Timestamp Modulo Event.
Hope that helps.
