Hello! I am using cvb drivers to use 2 cameras at the same time. The program i made seems to work just fine, but there is a strange behaviour happening when I put one of the camera on trigger mode (or both of them). When they receive the trigger, they start grabbing, but they auto set a high fps value (sometime to 135, sometime to 90) but it does not change the value inside the properties of the camera. Any clue what could be the problem?
thanks in advance! Best regards,
Pierre-Olivier Morin
Hi @morin
please try this with the CVB Viewer. If it does not happen there you did something wrong in your code. But this seems unlikely.
If it happens also in the CVB Viewer I assume an issue with the camera the camera settings or the external trigger signal which you use.
CVB itself does not change the framerate automatically. It acquires the images which we get from the camera.
