When using .vin files, we can specify that we want to access a camera’s images in its native Raw color format (through the Management Console).
How can we achieve the same thing when connecting to a camera through device discovery?
Currently, when I connect through device discovery, I always get images that are converted to 8-bit, even when I explicitly set the PixelFormat to Mono10.
I am accessing the pixel data using GetLinearAccess.
assuming you want to set the PixelFormat for the first device in your list. After that you need to retrieve the AccessToken as before and the JSON contains the parameter.
there is currently no list of such parameters because in v13.0 “PixelFormat” is realy the only one. The possible values are the same as in the known GenICam.ini. There will be more in future.
Looking into your feedback I found two problems:
a.) there was a typo in my original post. The “PixelFormat” needs to be with a capital “F” since the internal comparison is case sensitive. but b.) is more problematic since the format is internally overwritten. That is a bug which we will fix in 13.1. So the bad news is that in 13.04 you can NOT get the raw image when the driver is loaded through an AccessToken. Sorry for that.
If it is urgent I could send you a fix based on the official v13 but that would not be part of an official version.
