I am acquiring images using discovery rather than going via the .ini file and .vin mechanism.
I am setting the camera to output Mono12 data, but the image stream is providing 8 bit images. Is there an equivalent to setting the PixelFormat setting in the INI file which determines the buffer format supplied to the application?
Many Thanks
@BitSmith
Yes it is possible to do so. You can set all the mentioned parameters in .ini file before opening the device as follows:
var devices = DeviceFactory.Discover(DiscoverFlags.IgnoreGevSD | DiscoverFlags.IgnoreVins);
devices[0].SetParameter("NumBuffer", "30");
var dev = (GenICamDevice)DeviceFactory.Open(devices[0], AcquisitionStack.GenTL);
