How can I change the default pixel format for the GenICam Browser generated GenICam.ini file.
E.g. when I always want to use the RAW format as default value.
In the GenICamBrowser.xml file (%cvbdata%Applications) you can find this section:
<Parameter>
<ID>PixelFormat</ID>
<GUIName>CVB Color Format</GUIName>
<GUIDescription>Pixel format of the CVB Image.</GUIDescription>
<INIDescription>0 = Raw image whatever the device delivers; 1 = Mono 8Bit; 2 = RGB 8Bit; 3 = Mono 16Bit; 4 = RGB 16Bit; 5 = Auto Detect (default)</INIDescription>
<Type>Enum</Type>
<EnumValues>Raw,Mono 8Bit,RGB 8Bit,Mono 16Bit,RGB 16Bit,Auto Detect</EnumValues>
<DefaultValue>5</DefaultValue>
<MinValue>0</MinValue>
<MaxValue>5</MaxValue>
<HideInGUI>False</HideInGUI>
<UserConfigurable>True</UserConfigurable>
<INI>True</INI>
<TLVendors>All</TLVendors>
</Parameter>
Change the DefaultValue to 0.
