Number of valid lines
I am using the FrameBurstStart mode to get frames from a linear scan camera (GenICam). The frames are indeed acquired based on the frame trigger signal and the last buffer is incomplete, as should. How do I know how many lines are valid in this buffer ?
Hi @YvesDaoust,
this is a common challenge with gate triggered image acquisition. The solution is part of GenICam as this information is inserted in the “Trailer” of the image itself. To access this information with :cvb: you want to have a look into the IDeviceControl Interface here:
https://help.commonvisionblox.com/NextGen/14.0/md_theory_of_operation_hardware__gen_i_cam__c_v_b__user_guide.html#gcug_chmtopic3
SDK >> Supported Interfaces >> IDeviceControl Interface
The definition of the specific parameter can be found here:
%CVB%\Lib\C\iDC_GenICam.h
and the correct parameter for the variable image height is DC_BUFFER_INFO_DELIVERED_TRAILER_HEIGHT.
regards,
Theo
Despite the terseness of the available information, I made it work.
I found no place with a description of the parameter(s) for this command. Always a guesswork :frowning:
Thks anyway
Good morning,
thanks for your response. It will help us to improve our documentation for future releases.
Good to hear that your application is working now.
regards,
Theo
