Hi there,
When I do not have a camera attached, for my testing I use the CVMock.vin driver. However, it would be preferred if I could have mock image data that is more applicable to the application to aid camera-less testing. Is it possible to generate our own ‘mock.vin’ file, and if so, how can one go about doing this?
yes, it is in fact possible to configure what the CVMock.vin driver shows. The driver evaluates the CVMock.ini file which it is searching in either %CVBDATA%Drivers or in the application’s current directory (if the file exists in both locations, the one in the current directory has priority over the one in %CVBDATA%Drivers.
The file is - as the name implies - an old-style ini file with name/value pairs. There are a few of them sprinkled over the installation and most of them contain a description of how to fill them out, along with one or more sample configurations:
; INI for CVMock.vin
; The CVMock.vin driver will first attempt to find this configuration file in the working directory
; of the calling application. If none is found, the CVMock.ini from %CVBDATA%drivers is used.
; MockType:
; 0 -> MockVin generated image
; 1 -> Load Emu file from loadPath
; If .emu files with loadAtOnce = 0 are loaded, the buffer size is set to
; imgBuff which then mustn't be 0!
; 2 -> Load image files from loadPath
; LoadPath
; Location where images or .emu to load are stored. Shortcuts for the leading path
; component are available for:
; Environment strings:
; To utilize an environment string as a part of the path, use the
; respective name enclosed in percentage signs (%).
; E.g. %CVB%/tutorial
; Application directory:
; If the images are to be read from the application directory itself,
; @APPDIR is dynamically adapted to reference this path.
; E.g. @APPDIR/clara.bmp
; ImgPrefix
; Name which is part of each image to be loaded e.g. img001, img002
; FrameRate
; Display images in frames per second. This value overrides the .emu's frame rate specified by the "Delay" value.
; BufferCount
; Amount of images to be preloaded. 0 will load all available images at once
; except when loading from .emu which defines loadAtOnce on its own.
; Following parameters are only needed for mockType=0.
; BufferWidth
; Width of the buffer/image in pixels.
; BufferHeight
; Height of the buffer/image inpixels.
; BufferFormats:
; 0 -> Mono8 ramp pattern
; 1 -> RGB24 red ramp others 0
; 2 -> RGB24 green ramp others 0
; 3 -> RGB24 blue ramp others 0
; 4 -> Mon10 4 x Mono8 ramp
; 5 -> RGB30 4 x red ramp others 0
; 6 -> RGB30 4 x green ramp others 0
; 7 -> RGB30 4 x blue ramp others 0
; 8 -> Mono12 16 x Mono8 ramp
; 9 -> RGB36 16 x red ramp others 0
; 10 -> RGB36 16 x green ramp others 0
; 11 -> RGB36 16 x blue ramp others 0
; BufferRoll
; Steps to advance between images for moving buffer
; 256 steps available for all formats
; required for valid ini format
ProfileName=Default
[Board0_Channel0]
; default values if nothing but the port node is defined
; these lines cannot have comments next to themselves
MockType=1
LoadPath=%CVB%/tutorial/Polimago/Images/Cookies/_LoadMe.emu
FrameRate=50
imgBuff=5
