How to set CVB settings
I am trying to connect to many cameras by using:
        interface_flags = cvb.DiscoverFlags.UpToLevelInterface | cvb.DiscoverFlags.IgnoreGevFD
        broadcast_flags = cvb.DiscoverFlags.IgnoreVins | cvb.DiscoverFlags.IncludeInaccessible | cvb.DiscoverFlags.IgnoreGevFD
        all_devices = []
            for dev in found_devices:
                all_devices.append(dev)
        ids = cvb.DeviceFactory.discover_from_root(cvb.DiscoverFlags.IgnoreVins)
        self.camera = cvb.DeviceFactory.open(all_devices[0].access_token)
How can I set Number of buffers and CVB color format in this case? (did not find them in node_maps)
I am using these cameras:
2022-08-25 08_25_56-IVISYS Support - TeamViewer
Hi @Fatemeh
Sorry for the late response due to the vacation season.
You can set he number of buffers and CVB colorformat with the member function set_parameter() of the class DiscoveryInformation. In your case:
cvb.DiscoveryInformation.set_parameter(interface, "NumBuffer", "20")
cvb.DiscoveryInformation.set_parameter(interface, "PixelFormat", "5")
