Camera connection state changed event usage
I am developing a program in Ubuntu by using Python.
I try to use register_connection_state_changed_event like below
     interface_flags = cvb.DiscoverFlags.UpToLevelInterface | cvb.DiscoverFlags.IgnoreGevFD
        broadcast_flags = cvb.DiscoverFlags.IgnoreVins | cvb.DiscoverFlags.IncludeInaccessible | cvb.DiscoverFlags.IgnoreGevFD
        all_devices = []
            for dev in found_devices:
                all_devices.append(dev)
        ids = cvb.DeviceFactory.discover_from_root(cvb.DiscoverFlags.IgnoreVins)
        self.camera = cvb.DeviceFactory.open(all_devices[0].access_token)
        try:
            self.camera.register_connection_state_changed_event(self.call_back())
        except Exception as e:
            print(f"ex :{str(e)}")
By running this I get this exception : std::exception but I reach the call back code once.
Could you please help me with usage of register_connection_state_changed_event ?
PS : Tried the code below but I do not know which node name I should use to get the node and pass it to call back:
            self.camera.register_connection_state_changed_event(self.camera.node_maps["Device"].nodes.try_get_node("????"))
Thank you in advance
Hi @Fatemeh
Sorry for the late response due to the vacation season. The Following code block shows how to do connection monitoring in Python:
import os
import time
def connection_changed(dev: cvb.Device):
    print("Connection state changed: ")
device.register_connection_state_changed_event(connection_changed)
while True:
    time.sleep(1)
