ALVIUM MIPI CSI camera is found but no images are transfered
My camera is connected correctly and I can get data when I e.g. use cat /dev/video0 but I can not get images when I use CVB or the Vimba Viewer Tool.
I can also see the the LED starts blinking when I start streaming from the camera.
The reason for this behaviour could be a mismatch of the firmware version of the camera and the version of the TL used for MIPI CSI.
The ALVIUM camera firmware must always match the TL version.
E.g. if you use a TL with the version 6.0 or 6.1 a firmware version 10.xxx is required.
Use the AV Fimrware Update Tool to update to the required firmware.
