However when trying to assign the IP address, the ‘advanced configuration’ page seems to hang, then crash, and the management console window comes back into view.
Whether or not the next thing is related, id hope you could tell me, obviously at the moment we can’t set the IP, so the device is ‘yellow’ at the moment in the advanced configuration window, i can take this across to the port assignment list and save, the camera will then appear in the management console window. However, when trying to load the camera pragmatically, it always fails…
this should be the code to force an IP on the device:
auto allInterfaceFlags = Cvb::Driver::DiscoverFlags::UpToLevelInterface | Cvb::Driver::DiscoverFlags::IgnoreGevSD;
auto allInterfaces = Cvb::DeviceFactory::Discover(allInterfaceFlags);
// Let's say your camera is connected to the 4th interface found:
Cvb::Driver::DiscoveryInformation& iface = allInterfaces.at(4);
auto allDevFlags = Cvb::Driver::DiscoverFlags::IgnoreVins | Cvb::Driver::DiscoverFlags::IncludeInaccessible | Cvb::Driver::DiscoverFlags::IgnoreGevSD;
iface.SetGenApiFeature("TLInterface", "DisableSubnetMatch", "1");
iface.SetGenApiFeature("TLInterface", "AllowBroadcastDiscoveryResponse", "1");
// Find all devices connected to that device
auto devsFound = Cvb::DeviceFactory::Discover(iface, allDevFlags);
if (devsFound.size() > 0)
auto interfaceDevice = Cvb::DeviceFactory::Open(iface.AccessToken());
auto interfaceNM = interfaceDevice->NodeMap(CVB_LIT("TLInterface"));
auto deviceUpdateListNode = interfaceNM->Node<Cvb::CommandNode>(CVB_LIT("DeviceUpdateList"));
auto cfgIPNode = interfaceNM->Node<Cvb::IntegerNode>(CVB_LIT("IPCfg_IP"));
auto cfgSubnetNode = interfaceNM->Node<Cvb::IntegerNode>(CVB_LIT("IPCfg_Subnet"));
auto cfgMacNode = interfaceNM->Node<Cvb::IntegerNode>(CVB_LIT("IPCfg_MAC"));
auto cfgForceNode = interfaceNM->Node<Cvb::CommandNode>(CVB_LIT("IPCfg_SetForceIP"));
auto cfgStaticNode = interfaceNM->Node<Cvb::CommandNode>(CVB_LIT("IPCfg_SetStatIP"));
// make node map aware of the device
deviceUpdateListNode->Execute();
// we want to configure the found device with MAC
// 00-01-0D-C2-43-66
// reverse: 66-43-C2-0D-01-00
int64_t macReverse = 0x6643c20d0100;
cfgMacNode->SetValue(macReverse);
// New IP 169.254.0.1 -> hex: 0xa9fe0001
cfgIPNode->SetValue(0xa9fe0001);
// Subnet 255.255.0.0 -> hex: 0xFFFF0000
cfgSubnetNode->SetValue(0xFFFF0000);
// Force the new IP
cfgForceNode->Execute();
// make node map aware of new IP
// permanently write the IP to the camera
cfgStaticNode->Execute();
