Hi,everyall!
I have a question about the polimago search and classify models.
I used the trained search model and classify models to test the same image with the same parameters for many times.
why are the results different?
Can you tell the reason,thanks a lot.
The phenomenon is as follows:
Hi @JieZhao,
I’ll need more information to answer this one. What are you doing exactly? You mention search and classify - are you working with two classifiers simultaneously? What does that graph show? What does the code look like?
Generally speaking: When using the same classifier with the same settings on the same image the results are the same. Is there a chance to save the image if the result deviates from the expectation to have a look at it?
