Polimago Classification & Regression to verify the pictusres
Dear sir or madam:
I want to verify the pictures which used to train to a classifier can be classified to correct class. But the Sample test result is differenent to my C# program test result.
My Experiment below
I create a new Polimago Classification & Regression to make a pass and fail classifier.
First, I load image and create the pass and fail classes.
Second, I do the Create Classifier to train the classifier.
Third, I save the Polimago classifier file.
Forth, I do the Sample Test to check the training result.
Test_Results
After using TeachBench to make classifier, I use the Visual Studio 2019 C# to Load the classifier I trained and Load the pictures which used to train classifier. But the test result is different to I use Teach Bech Sample Test result.
my Cap test
I also try CVB tutorial Handwriting classifier USDigits6000.pcc. The result is also different, show below.
TeachBench_TestDigits
My C# Code
using Stemmer.Cvb;
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using Cvb;
using CVBImage = Cvb.Image;
using System.IO;
namespace WindowsFormsApp1
    public partial class Form1 : Form
        private Cvb.SharedPolimagoClf theClassifier_;// The Polimago classifier to be used.
        string number = "1";
        string file_path_ = @"D:\test\1";
        string file_type_ = "*.bmp";
        int pass_count_ = 0;
        int fail_count_ = 0;
        public Form1()
            InitializeComponent();
            LoadClassifier("USDigits6000.pcc");
            Classify();
        private void LoadClassifier(string fileName)
                Cvb.SharedPolimagoClf tmp = Cvb.Polimago.OpenClf(fileName);
                if (tmp != null)
                    theClassifier_ = tmp;
                    Console.WriteLine("Loaded classifier '" + fileName + "'");
            catch (Exception e)
                Console.WriteLine(e.ToString());
        private void Classify()
                DirectoryInfo di = new DirectoryInfo(file_path_);
                foreach (var fi in di.EnumerateFiles(file_type_))
                    Cvb.Image.IMG image = 0;
                    bool r = Cvb.Image.LoadImageFile(fi.FullName, out image);
                    Cvb.Image.IMG normalize_image = 0;
                    Cvb.Image.CreateNormalizedImage(image, CVBImage.TNormalizeMode.Normalize_MeanVariance, 128, 120, out normalize_image);
                    double quality;
                    string cls;
                    double[] confidences;
                    if (theClassifier_.Classify(normalize_image, 0, 0, out cls, out quality, out confidences))
                        if (cls == number)
                            pass_count_++;
                            string ng_message = fi.FullName + " ==> " + confidences[0].ToString() + " " + confidences[1].ToString();
                            Console.WriteLine(ng_message);
                            fail_count_++;
                Console.WriteLine("Pass count : " + pass_count_.ToString());
                Console.WriteLine("Fail count : " + fail_count_.ToString());
            catch (Exception e)
In regard to your code, it seems like you are performing the classification on normalized images. The samples test in the TeachBench is performed on the training set images (that are probably not normalized).
Dear Frank:
Thank you for helping me.
But my training set images on TeachBench which already be normalized images.
TeachBench’s teach result by normalized images
Test_Results
This is a sample test on the training set and not a hold-out test, is this correct?
Hi Frank:
THis result is Sample Test result on the training images set.
Test_Results
Hi Jesse,
I’m running your code and check if I have the same result and check if I find any possible explanation. The results should be the same as they use the same functionality under the hood.
In your code you use bmp files to load images. Where did you get the USDigits6000 images from? The Polimago folder has only a xsil stored together with the classifier file.
Hi Phil:
I click 0~9 class and mouse right click to save the hand writing images.
I save all hand writing images to bmp images.
By “exporting” the images this way from the XSIL the images might be changed slightly as a result. This might explain the different results when doing the classification manually compared to the sample test.
That said, for this hand writing set, the images are not normalized within the training set (XSIL). Do you skip the normalization when doing your test in your application for this set? Or have you created a new XSIL based on normalized images?
I have tested your code with the digits and found the error. If you skip the normalization in line 69 and classify directly on the image the results match the ones obtained by the teachbench. I also reloaded all images into the teachbench after saving them as .bmp and the results stay the same.
Here is the code for the class 5 (since there is one easy to spot difference)
using Stemmer.Cvb;
using System;
using System.Data;
using System.Linq;
using System.Text;
using Cvb;
using System.IO;
        string number = "5";
        string file_path_ = @"D:\test\5";
        public Form1()
            Classify();
                if (tmp != null)
            catch (Exception e)
                    double quality;
                    string cls;
                    if (theClassifier_.Classify(image, 0, 0, out cls, out quality, out confidences))
                        if (cls == number)
                            pass_count_++;
                            fail_count_++;
            catch (Exception e)
The above code returns 0 errors which is the same result as in the teachbench, while your version was returning one false label.
I assume something similar is causing the problem with your original data.
