I am getting the following error when trying to open the GenICam.vln file in Image View:
Unable to load file C:\Program Files (x86)\STEMMER IMAGING\Common Vision Blox\Drivers\GenICam.vln
I also have a stand alone application attempting to use this file and get no image on screen when it is used. No other application is using the file at these times.
If I use the CVMock.vin file everything works fine.
The camera can be accessed from the management console with no problem.
Potential hint - I installed the x64 version initially by mistake. I’ve since uninstalled and deleted as much as possible all files/folders relating to it and installed the x32 version. Could there be an issue there?
Thanks for your time,
