Simple python script to poll or update nodes
My company make lighting controllers and support various registers for controlling behaviour. I need a way to periodically read the data, but I don’t seem to be able to do so after the first connection and read. What should I do? Below is the script I’ve written so far…
def main3():
    device = None
    readable_nodes = (
        cvb.IntRegNode,
        cvb.FloatNode,
        cvb.IntegerNode,
        cvb.EnumerationNode,
        cvb.CommandNode,
        cvb.StringRegNode,
        cvb.BooleanNode)
    nodes_to_read = (
        "Cust::ChannelDutyCycle",
        "Cust::ChannelLoadCurrent",
        "Cust::ChannelLoadVoltage",
        "Cust::ControllerTemperature",
        "Cust::TriggerCount"
    try:
        serial_number = "920062"
        device = connect_to_controller(serial_number)
        if device is not None:
            for t in range(5):
                for name, node in dev_node_map.nodes.items():
                    try:
                        if isinstance(node, readable_nodes):
                            # print(dir(node))
                            if node.is_readable:
                                if node.name in nodes_to_read:
                                    print(f"{node.name}, {node.display_name}, {node.description}, {node.tool_tip}, {node.value}")
                        else:
                            pass
                            # print(node.name)
                            # print(type(node))
                    except Exception as e:
                        print("Exception reading node: " + str(e))
                time.sleep(5)
                dev_node_map.poll_nodes()
                dev_node_map.nodes.update()
        print(e)
    finally:
            device.close()
main3()
Hi @adam.honeybell
if you know which nodes you want to read, there is no need to query all of the nodes.
Here is a simple example:
import os
# Read and write values from/to NodeMap
#Tested With Dalsa Genie Nano, names of Nodes may be different on other devices
# Load driver  -> You can keep your routine to open a device here with your
# connect_to_controller() as this seems to be working fine.
#Load NodeMap for the device
camModel = dev_node_map["DeviceModelName"]
print("Loaded device: " + camModel.value)
camFirmware = dev_node_map["DeviceFirmwareVersion"]
print("Current Firmwareversion : " + camFirmware.value)
exposureTime = dev_node_map["ExposureTime"]
print("Current exposure time : " + str(exposureTime.value))
exposureTimeOld = exposureTime.value
exposureTime.value = 32
print("Small exposure time : " + str(exposureTime.value))
exposureTime.value = exposureTimeOld
print("Resetted to old exposure time : " + str(exposureTime.value))
So in your case you would only want to iterate through your nodes_to_read and check the nodemap at the corresponding entry like: dev_node_map[current_node_to_read]
