Setting Exposure Time via Node Map
Hi, in relation to your posts, i’m attempting to take consecutive photo’s with increasing exposure time, but i’m unsure how to alter the node value for exposure time?
this is what i have
import os
with cvb.DeviceFactory.open(os.path.join(cvb.install_path(), "drivers", "GenICam.vin"), port=0) as device:
    stream = device.stream
    device_node_map = device.node_maps["Device"]
    #exposure = device_node_map["ExposureTime"]
    for i in range(10):
        device_node_map["ExposureTime"].value(i*1000)
        img, status = stream.wait()
            print("Acquired image: " + str(i))
        img.save("C:\\Users\\TechHP1\\Pictures\\newattempt" + str(i) + ".jpg")
    stream.stop()
anyone have any ideas?
Hi @Adam,
can you tell us more what actually is wrong with your code? On the first look this code seems ok to me.
Only thing I can imagine is that if the camera is in freerun mode you might be to slow to change exposure settings for each frame. Better would be to use a software- or hardware trigger.
regards,
Theo
@illusive, can we copy this question to a new topic?
Hi, i managed to get it to work but i had to change the exposure time variable to a string and use the from_string function, i couldn’t get the value function to work. The code below works as intended though if anyone ever wants to use it
import os
#opens the camera
    #starts streaming
    #calls the node map
    for i in range(10):
        exposure=(i+1)*10000
        val = str(exposure)
	#change exposure to a string and define variable
        device_node_map["ExposureTime"].from_string(val)
	#this changes the exposure time to whatever value val has
	#waits till next image is ready and takes it
    stream.stop()
Hi @Adam,
at first I missed your issue - but now I see.
Node.value is not a method but a property device_node_map["ExposureTime"].value = i * 1000 should work fine.
