Hi, im trying to set the vlaue of the nodemap in python. It does work for node like AquisitionMode.TriggerSelector or AquisitionFramecount for Example:
please be aware that the trigger source node is an enumeration node. This means it only takes a certain set of predefined values (enum entries) as values. You can get a list of all possible values via EnumerationNode.entries. This property will return a list EnumEntryNodes each with a diffrent numeric and symbolic value. The symbolic value can be used to set the enum.
You may have a look at the node via the GneiCam bowser. Please note that the display name may not be the same as the symbolic value.
