Accessing CVB Management Console Camera Properties via Python
I’m trying to access and change the same camera properties that is accessible through the CVB Management Console, for example AOI-tracking and Camera Mode, using the Python API. I have tried to look in the documentation without any luck.
Edit.
I have found a way to read the properties via the NodeMap class dictonary “nodes”, but I still dont know how to change them.
Thank you for the help,
Trym
Hi @trymdh
you can find a tutorial that shows how to edit NodeMap values in your installation directory of CVB:
C:\Program Files\STEMMER IMAGING\Common Vision Blox\Tutorial\Image Manager\CVBpy\DeviceConfiguration
It shows the configuration of a camera for being software triggered and also how to execute the SoftwareTrigger:
import os
triggerModeNode = dev_node_map["TriggerMode"]
triggerModeNode.value = "On"
triggerSourceNode = dev_node_map["TriggerSource"]
triggerSourceNode.value = "Software"
softwareTrigger = dev_node_map["TriggerSoftware"]
softwareTrigger.execute()
I hope this was what you were looking for.
Thanks, I figured it out:)
Thank you for your time
Trym
@Andreas how do you get the output of the additional node information in the image above? I’m using Python with VS code.
nvm, I got it :slight_smile:
Hi and welcome @ravikumar89!
I am sorry, but I honestly do not think that your post is making an actual contribution to the issue discussed here. If you think you can help, please be more specific than that.
