I have a question about the C++ API of
I am using the latest version (14.00.010) of
at this time.
The class Cvb::DiscoveryInformation defines a move constructor and declares a defaulted move assignment operator. (However the move constructor of Cvb::DiscoveryInformation behaves like a copy constructor.)
Because of that, instances of Cvb::DiscoveryInformation cannot be copied.
From cppreference.com:
The implicitly-declared copy constructor for class
Tis defined as deleted ifTdeclares a move constructor or move assignment operator.
Why should instances of Cvb::DiscoveryInformation class not be copied?
It is just a std::shared_ptr and an int.
If this is the intended behavior, why not just use a std::unique_ptr instead of std::shared_ptr as the member?
Why I want to copy Cvb::DiscoveryInformation:
I would like to store instances of Cvb::DiscoveryInformation, wrapped in std::any, in my own struct because our application needs to deal with other APIs too. I then later open a camera from the data in this struct. The struct should manage the lifetime of the Cvb::DiscoveryInformation instance(s) and therefore the lifetime of the list, that they point to.
Right now, I’m doing the discovery again for each camera that should be opened, however, even one discovery takes several seconds. I want to avoid doing multiple discoveries.
The class
anydescribes a type-safe container for single values of any copy constructible type.
Is it safe to modify the C++ header files myself? (Removing move constructor & assignment operator or declaring defaulted copy constructor(s) and copy assignment operator(s))
If yes, can this be changed in a future release?
