Buffer overflow when repeatedly calling Cvb::DeviceFactory::Discover
After about 20 minutes running (even without cameras) buffer overflow happens caused by Discover function. This only happens when running app inside Docker.
Program Output:
calling discover504
discover called504
calling discover505
discover called505
calling discover506
discover called506
calling discover507
*** buffer overflow detected ***: /home/app-build/build/discover-test terminated
Dockerfile:
FROM ubuntu:18.04 AS builder
ENV BUILD_FOLDER=build
WORKDIR /home
# Build image
## Essential packages
RUN apt-get update && apt-get upgrade -y && apt-get install -y \
  build-essential \
  cmake \
  git \
  libgtest-dev \
  libice6 \
  libsm6 \
  sudo \
  unzip \
  libfontconfig1 \
  libfreetype6 \
  wget \
  libxext-dev \
  libgtk-3-dev \
  libglade2-0 \
  libglade2-dev \
  libpcap0.8 \
  libcap2 \
  ethtool \
  tar
ARG ARCH=""
ARG CVB_VERSION=13.02.002
RUN mkdir libcvb && cd libcvb
RUN if [ ! -z ${ARCH} ] && [ ${ARCH} = "aarch64"  ]; \
      then wget ftp://ftp.commonvisionblox.com/forum/setups/cvb/linux-aarch64/cvb-${CVB_VERSION}-ubu1804-aarch64.zip; \
      else wget ftp://ftp.commonvisionblox.com/forum/setups/cvb/linux-x86_64/cvb-${CVB_VERSION}-ubu1804-x86_64.zip; \
    fi
RUN unzip -o cvb-${CVB_VERSION}-ubu1804-*.zip && \
  chmod +x ./install_cvb.sh && ./install_cvb.sh && ldconfig
## Discover Test
WORKDIR /home/app-build
COPY . ./
WORKDIR $BUILD_FOLDER
RUN . /etc/profile.d/cvb_environment.sh && cmake .. \
    && make -j4
ENTRYPOINT ["../scripts/run_app.sh", "/home/app-build/build/discover-test"]
start script, run_app.sh:
#!/bin/bash
if [ "$#" -ne 1 ]; then
  echo "Usage: $0 APP_NAME" >&2
  exit 1
fi
CVB_VERSION="13.02.002"
APP_NAME=$1
ln -sf /opt/cvb /opt/cvb-$CVB_VERSION
if [ $? -ne 0 ]; then echo 'Unable to create symbolic link'; exit 1; fi
if [ $? -ne 0 ]; then echo 'Unable to load CVB enviroment variables'; exit 1; fi
/etc/init.d/siLogSvc start &> /dev/null
if [ $? -ne 0 ]; then echo 'Unable to start CVB log service'; exit 1; fi
/etc/init.d/siGevSvc start &> /dev/null
if [ $? -ne 0 ]; then echo 'Unable to start CVB GigE daemon service'; exit 1; fi
/etc/init.d/cvmgmtd start &> /dev/null
if [ $? -ne 0 ]; then echo 'Unable to start CVB management daemon service'; exit 1; fi
${APP_NAME}
if [ $? -ne 0 ]; then echo 'Unable to run ${APP_NAME}'; exit 1; fi
exit 0
Test code:
#include <iostream>
int main(int argc, char *argv[])
  int cnt = 0;
  while(1)
    std::vector<Cvb::Driver::DiscoveryInformation> discover;
    std::cout << "calling discover" << cnt << std::endl;
    discover = Cvb::DeviceFactory::Discover(Cvb::Driver::DiscoverFlags::IncludeInaccessible
                                          | Cvb::Driver::DiscoverFlags::IgnoreVins);
    std::cout << "discover called" << cnt << std::endl;
    cnt++;
This sounds very much like a bug we have already fixed with CVB 13.3.4 and later.
Please try updating to at least CVB 13.3.4 and let us know if this fixed the issue.
Thanks!. Updated to CVB 13.4.0 and the problem seems fixed.
