GenICamBrowser not showing any device
I can put only 1 image per post so i’ll put links instead.
GenICamBrowser application is loading infinitely on “Discover devices” when I start it :
There is nothing in the list and the cursor is loading.
And all the icons are grayed out
The only way that I have to have access to 3 of those few options is to go to View -> Show / hide TLs… and click “OK”
Then :
And if i click on that second icon to ignore the subnet, it does nothing more than “Ready”…
The mouse cursor is always loading.
Here are my network interfaces:
enp0s31f6: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 20:46:a1:02:cd:6f  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 16  memory 0xdf600000-df620000
enp3s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.36  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::2246:a1ff:fe02:cd70  prefixlen 64  scopeid 0x20<link>
        ether 20:46:a1:02:cd:70  txqueuelen 1000  (Ethernet)
        RX packets 8157  bytes 1265634 (1.2 MiB)
        TX packets 8615  bytes 5020372 (4.7 MiB)
        device memory 0xdf500000-df57ffff
enp4s0f0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 169.254.123.28  netmask 255.255.0.0  broadcast 169.254.255.255
        inet6 fe80::2c9c:3b8:2f7d:e620  prefixlen 64  scopeid 0x20<link>
        ether b4:96:91:24:cd:50  txqueuelen 1000  (Ethernet)
        RX packets 12698  bytes 18843070 (17.9 MiB)
        TX packets 408  bytes 30885 (30.1 KiB)
        device memory 0xdf300000-df3fffff
enp4s0f1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b4:96:91:24:cd:51  txqueuelen 1000  (Ethernet)
        device memory 0xdf200000-df2fffff
enp4s0f2: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b4:96:91:24:cd:52  txqueuelen 1000  (Ethernet)
        device memory 0xdf100000-df1fffff
enp4s0f3: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b4:96:91:24:cd:53  txqueuelen 1000  (Ethernet)
        device memory 0xdf000000-df0fffff
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Boucle locale)
        RX packets 1460  bytes 311170 (303.8 KiB)
        TX packets 1460  bytes 311170 (303.8 KiB)
ztrf23fe4s: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 2800
        inet 10.147.17.56  netmask 255.255.255.0  broadcast 10.147.17.255
        inet6 fe80::94ac:5bff:fe6e:91ce  prefixlen 64  scopeid 0x20<link>
        inet6 fc19:5094:2ab:7a6a:55d::1  prefixlen 40  scopeid 0x0<global>
        ether 96:ac:5b:6e:91:ce  txqueuelen 1000  (Ethernet)
        RX packets 6325  bytes 454455 (443.8 KiB)
        TX packets 5129  bytes 6018039 (5.7 MiB)
The 2 cameras are on the enp4s0f0 interface.
And here is my /etc/opt/cvb/drivers/GenICam.ini file :
[SYSTEM]
CreateAutoIni=0
StartupPort=0
NumCameras=2
[Channel_0]
TL=/opt/cvb/drivers/genicam/libGevTL.cti.1.1700.459
Interface=SD::MAC->B4-96-91-24-CD-50
Device=::ID->00-01-0D-C3-4A-A8::169.254.0.1
Vendor=Teledyne DALSA
Model=Nano-C4900
UserName=S1156987
SerialNumber=S1156987
MCMasterMode=0
MCSession=0
MCNoJoin=0
PacketSize=-1
InterPacketDelay=-1
PixelFormat=5
NumBuffer=3
RotateImage=0
ConvertAlways=0
AccessMode=4
AttachChunk=0
UseTurboDrive=0
[Channel_1]
Device=::ID->00-01-0D-C3-4A-AA::169.254.7.223
Model=Nano-C4900
UserName=S1156989
SerialNumber=S1156989
MCMasterMode=0
MCSession=0
MCNoJoin=0
PacketSize=-1
InterPacketDelay=-1
PixelFormat=5
NumBuffer=3
RotateImage=0
ConvertAlways=0
AccessMode=4
AttachChunk=0
UseTurboDrive=0
I tried cleaning this file but it generates back when I open GenICamBroswer.
Can somebody help please ?
I did not mention that the CPP program is working fine (except that it takes 1 photo instead of 10) :
As said here Cannot start GenICamBrowser - libpng missing, I needed to add a few env vars to the .xsessionrc file :
CVB=/opt/cvb
GENICAM_GENTL64_PATH=/opt/cvb/drivers/genicam
CVGENICAM_REGISTRY=/var/opt/cvb/Registry
GENICAM_CACHE_V3_0=/var/opt/cvb/genicam
CVBDATA=/var/opt/cvb
CVBCONFIG=/etc/opt/cvb
In order to avoid “regenerating” Genicam.ini: Replace the content with …
[SYSTEM]
CreateAutoIni=0
If the file is deleted a new file with …
[SYSTEM]
CreateAutoIni=1
will be created. And then any access to the .vin driver will start a discover over all interfaces (that means all transportlayers). Which then results in your devices being inserted in Genicam.ini.
You may also run into an issue with services which are not running (because they are not called by debian).
siGevSvc ( needed for “ownership” to a Gige Camera, otherwise you will not be able to open them)
siLogSvc ( logging )
cvmgmtd ( our “management service” )
Should look like this:
user@chartmannX64:~$ ps -ef | grep cvb
root       798     1  0 09:39 ?        00:00:00 /opt/cvb-13.01.000/bin/siLogSvc -s
root       900     1  0 09:39 ?        00:00:00 /opt/cvb-13.01.000/bin/siGevSvc -s
root      1045     1 12 09:39 ?        00:00:03 /opt/cvb-13.01.000/bin/cvmgmtd
user      3037  3027  0 09:40 pts/0    00:00:00 grep --color=auto cvb
I’m confident that they are running for you ( you are able to access a cam ).
$ ps -ef | grep cvb
root       420     1  0 09:11 ?        00:00:19 /opt/cvb-13.01.002/bin/cvmgmtd
root       441     1  0 09:11 ?        00:00:34 /opt/cvb-13.01.002/bin/siGevSvc -s
root       449     1  0 09:11 ?        00:00:01 /opt/cvb-13.01.002/bin/siLogSvc -s
user      1771   826  5 09:12 ?        00:15:06 /opt/cvb/bin/GenICamBrowser
user      5574  1439  0 13:42 pts/0    00:00:00 grep cvb
Yes indeed I can access a cam and configure options etc. Problem solved, thanks again.
