CVGenApiGrid : How to change the font size?
Dear colleagues,
Do you know how increase size of text (font size) of your CVGenApiGrid component?
Thanks in advance for your answer.
Best regards,
Benjamin Viaron
Tech Support Manager
Hi @Bviaron, this is not supported directly via a Property. The CVGenApi Grid ActiveX control uses the system’s default font size.
Thus changing the system’s font size also increases the fonts in the grid (after the app was restarted).
Hi @parsd, thanks for your quick answer.
So now, I imagine I need to go to the Control Panel of Windows and change the default font size, right ?
Yes, that should do the trick. But then of course all fonts are larger…
