Hi @Sebastian ,
The camera is actually GigE. Not sure, why it is calling to the USBTL. The result for lsual command is:
The error shown on the command line for opening the camera through code is “Unspecified GenTL error” (the “Segmentation fault” has gone away):
The logging window shows majorly the previous errors, except for a new warning at the line 4 (Caught Exception in CVFIFGetDeviceInfo : TL Error: -1007, Invalid DeviceInfoId 1113)
The device is now visible on GeniCam browser and openable through the “Available Devices” window on the left. The configuration of the camera have also been saved to the “Configured Devices” window on the right and saved to the GenIcam.vin file through the button given above on the application icon bar.
The device is not openable through the “Configured Devices” (In the logging window below, it mentions: Cannot open device. Error finding interface for the device. The logging of camera opening and closing through “Available Devices” can also be seen above this logging line):
Edit: The device is now openable through Configured Devices, (this portion of text mentioned in curly brackets), not sure why, though the aforementioned Code based “Unspecified GenTL error” is still there:
The Configuration Settings for this device are:
The GeniCam.vin file details are shown here (kindly note it mentions modified date of 18 March, accessed date unrelated to opening through the code or browser, as it didn’t update when I just tried it)
P.s: Not sure if it is related, PC seems to have remnants of previous CVB version 13.04.004 though I properly uninstalled it through the uninstall_cvb.sh command and rebooted the PC, the clock on this PC also happens to be one hour ahead normal time.
Kindly feel free to let me know if you know a prospective direction in which this could be explored or if there is a setting that I may be missing to make the Configured GeniCam.vin file available. I will be looking forward to hearing from you.
Kind regards,
Maggi
