I am using AT C5 and AT C6 for a few years.
actually, it is possible to consult live the encoder counter value (ant it is even possible to reset it). Later, if an image is trigged, the image arrives with encoder counter value in chunk acq infos (and also image timestamp).
So, for the encoder it works to :
- read live encoder value (even though no images are taken)
 - get chunks when an image arrives (encoder value and timestamp)
I know “GevTimestampControlReset” is not working with this camera (to reset timestamp). ( ATC6 timestamp reset cvb++ - Programming Questions / C++ API - Common Vision Blox User Forum)
Is there a node (or a way) to read current time in camera even though no images are taken ?   The goal is to memorise this value to manage timestamp reset in my  side.
Reason: I would like to avoid to synchronize my system with coderstamp (sometimes encoder signal is not so clean and the diffferent electronics does not count the same), I would like to use timestamp (like I do for other kind of cameras).
Thanks in advance,
Mikael.
