I’m using cvb.net for a basic live display in c# application.
I had a few occurence where the image look like the below on app startup. The camera is looking at a green backlight so the full image is green in normal acquisition condition.
I have an idea about what the problem is. If you are changing settings that concern the memory of an image (e.g. ‘PixelFormat’), we need to update the image data. This way, we get the data that we expect.
Does your application immediately acquire and display an image when it starts after loading the driver? You could try to disable “Snap Image On Load Driver” in the Windows registry. This setting can be found under “HKLM\SOFTWARE\Common Vision Blox\Image Manager”. In older CVB versions this setting is also exposed in the Management Console if I recall correctly.
