Fixed GCBrowser failures with third-party GEVTLs (e.g., Vimba and Emergent) when applying AccessToken parameters to unimplemented stream nodes. AccessToken properties are now applied defensively, consistent with device-level handling.
Rebuilt for CVFactory changes.
Fixed corrupted images after image conversion (debayering / TurboDrive) when using 90- or 270-degree rotations.
CVGenApi.dll (3.6.1)
Handled file size nodes in NMDownloadFile when no EOF marker is present.
CVCDriver.dll (4.9.1)
Fixed issues when the service is not running and corrected the classic OEM reset.
CVMockTL.cti (1.3.22)
Enabled opening a device without UpdateDeviceList.
Added support for using stream files as a data source for GenDC streaming.
Added configurable frame ID start and maximum values based on the number of containers in a stream file.
CVFactory.dll (5.3.3)
Removed automatic UpdateDeviceList calls after failed opens to prevent flooding in multi-camera systems.
GevTL.cti (1.27.7)
Removed unwanted broadcast fallback.
Fixed a leak in subnet list strings.
Removed a leak in interface information.
GevSD.dll (2.18.3)
Fixed handling of streams with missing trailers to prevent segmentation faults when reading nonexistent data.
CVBNet.api (2.11.1)
Removed Trace.Assert from public code paths.
Improved VinBufferNodeMap performance.
LicenseManager.exe (1.3.7)
Reenabled CameraSuite on ARM.
Added new CameraSuite licensing contents.
CVMgmtSvc.exe (2.19.7)
GenICamBrowser.exe (4.15.0)
Updated the recorder, GevServer, and spectral plugin.
Added suggested StreamRecorder padding based on packet-size alignment after each part in a multipart stream, and added free disk-space calculation.
Added container IDs and timestamps to StreamRecorder and GevServer.
cvbpy.api (1.11.7)
Updated the error message with the active Python environment path.
Added CodeReader performance parameters and time-limited decoding.
Added DeviceFactory.open overloads for DiscoveryInformation.
Bumped the version to link with the new cvbpp version.
CVCore.dll (1.7.2)
Added CVCCompressedPFNCBufferFromPointer and updated PFNC.h.
cvbpp.api (1.11.4)
Added DeviceFactory::Open overloads for DiscoveryInformation.
Security critical update. be aware, that the update will upgrade the shell extension (which can lead to explorer freezes in the upgrade scenario) and the vendor recommends a reboot. Please contact our support for more information.
siNetFilter.sys (2.7.3.11)
fixes to ensure the last data packet (GenDC) is not discarded incorrectly
CVMockTL.cti (1.3.23)
Send valid Jpeg test data
GevSD.dll (2.18.4)
introduce reported min buffer count and configurable credits
GenICam.vin (3.5.0)
adapt attach chunk logic
introduce a fallback check for incomplete frames, if camera doesn’t support preliminary/final descriptors (RDMA)
GenICamBrowser.exe (4.16.0)
automatic RDMA switch on/off handling
save consecutive images reenabled
message for not completely transferred payloads
Jpeg decompression for display
load speedup
cvbpp.api (1.11.5)
changed CVB version function name
GevTL.cti (1.27.9)
Respect inverted GVSPNotSupported flag
add configurable credit count (RDMA) and technology specific min buffer count
restored IP configuration logic (discovery)
cvregistry.dll (3.7.3)
Tolerate existing files
CVGevServer.dll (3.10.7)
Rebuild and version increment for race in noderead and write.
