Version History
14.00.003 [2023-03-30]
CVB++ API no version change
Updated the CppCudaMemory example.
Fixed a bug in the DeviceFactory::OpenPort method of the wrapper.
CVBpy Wheel no version change
Rebuilt to make the fix for DeviceFactory::OpenPort available in CVBpy.
Improved interoperability of images and point clouds with numpy.
CVCDriver.dll 4.3.8.1000
CVFactory.dll 5.0.10.937
Fixed a initialization issue that did lead to problems with DeviceFactory::OpenPort.
CVMgmtSvc.exe 2.19.2.903
Improved resilience on Linux to situations where the CodeMeter daemon did not finish initialization by the time the cvmgmtd daemon is launched.
Adapted to shared object name change in the Linux build of the CodeMeter runtime.
CVCUtilities.dll 4.15.0.777
Corrected version reporting under Linux.
GenICamBrowser.exe 4.9.1.1655
Fixed a synchronization issue that could lead to an access violation when closing a camera window or the entire application.
Modified the approach to setting a camera’s IP address to the GEV compliant way.
GevTL.cti 1.26.1.712
Expose Action Commands under standard GenICam naming conventions.
Enabled GEV compliant way of setting a camera’s IP address.
TeachBench.exe 1.64.2.1367
Fixed a binding error in Polimago Classification and Regression module that led to an uncaught exception during project creation.
14.00.004 [2023-05-03]
Included missing stub files.
CVGenApi.dll 3.3.1.171
Fixed access violation when trying to download a file from a device when the file size is reported as zero bytes.
CVSetup.dll/CVSetup.exe 2.4.0.1
Rebuilt to eliminate an indefinite stall of the :cvb: installation/deinstallation that seems to occur on recent Windows 10 and Windows 11 versions during the installation/deinstallation of the siNetFilter driver.
CVUAL.dll 1.14.6.518
Improved performance when working with many cameras.
Improved performance when working in WSL Linux environment.
GenICam.vin 3.2.34.1690
Fixed order of clean up after stream stop to prevent potential buffer loss.
GenICamBrowser.exe 4.9.2.1656
Made packet size configurable.
GEVFD.dll 2.5.11.327
Corrected handling of camera overrun status reports from devices.
GEVSD.dll 2.17.1.665
Fixed an unhandled exception in TCP Offload mode when a packet with an extended GEV 2.0 block ID arrives.
14.00.005 [2023-05-30]
CVFactory.dll 5.1.0.939
Updated for rolling out an internal signature change.
14.00.006 [2023-06-23]
GenICamBrowser.exe 4.10.2.1666
Fixed devices not being closed correctly in some scenarios. Fixed issue when assigning IP address to a device on an interface linked to more than one device.
GEVTL.cti 1.26.2.714
Fixed static IP address not being set correctly for some devices.
14.00.007 [2023-10-05]
CVCDriver.dll 4.3.9.1001
Check handle validity in NMHGetNodeMap.
CVGevServer.dll 3.7.7.1207
Removed support for deprecated packed pixel formats.
GenICam.vin 3.2.35.1693
Make sure all buffers are discarded after an acquisition has been stopped to prevent leaking buffers.
GevFD.dll 2.5.12.329
Corrected handling of discarded data.
GevSD.dll 2.17.3.672
Corrected queue underrun counting.
GenICamBrowser.exe 4.10.3.1668
Simplified closing of multi stream devices.
GEVTL.cti 1.26.3.716
Correctly report buffer completeness now.
14.00.008 [2023-11-08]
collect-camsuite.exe 1.5.0.0
Updated to address the CameraSuite key provider web API under its new address. This reinstates the possibility to retrieve CameraSuite license keys in the GenICamBrowser and LicenseManager applications.
GevTL.cti 1.26.4.719
Modified to properly close disconnected color devices now.
SystemBrowser.exe 1.125.2.949
Fixed closing of disconnected devices.
14.00.009 [2024-01-10]
CVBpy
Fixed the usage of wait and wait_for method in handle_async_stream overrides.
CVCImg.dll 4.19.0.1005
Fixed an issue in the CreateDuplicateImageEx function that led to an access violation when copying images with more than 2 GByte pixel data.
GenICam.vin 3.2.36.1695
Fixed disconnect notification for U3V devices. Note: A GEV-like reconnect will not be possible with U3V.
14.00.010 [2024-02-26]
collect-camsuite.exe 1.5.1.0
Corrected URL for license queries.
CVBpp
Fixed wrapper for CVCImg.dll function ImageHistogram.
CVBpy
GEVTL.cti 1.26.5.726
Fixed data alignment for ReadMem functions.
14.01.000 [2024-05-27]
Major Release - please refer to the product release notes for the list of changes.
14.01.001 [2024-07-29T22:00:00Z]
GenICam.vin (3.2.39)
  • fix multipart VPAT cache creation
  • fixed PC Events
  • fixed TD on 2nd gen stack
  • Fixed DC_BUFFER_INFO_NUM_PACKETS_MISSING
SF_cuda.dll
  • removed from installer
GevSD.dll (2.17.5)
  • resolve large data transfer issue
GEVTLBase.lib (2.10)
  • RDMA: introduce buffer layout table
GevTL.cti (1.26.10)
  • set stream enable bit according to GEV standard
CVCDriver.dll (4.3.13)
  • resolve string termination issue for wide strings
CVPolarization.dll (1.02)
  • Removed CUDA
GenICamBrowser.exe (4.11.0)
  • Add support for device firmware update
  • add don’t show again option for reverse path filter info message on Linux
FWUpdater.exe (2.0.1)
  • Add support for device discovery
CVRegistry.dll (3.6.1)
  • Support fetching an XML file as a byte array
CVMockTL.cti (1.3.11)
  • Delegate the Buffer Port functionalities to the correct module
TeachBench.exe (1.67.1)
  • Fix Polimago overlay classifying incorrectly
CVFactory.dll (5.2.0)
  • Support directly downloadeing XML files from the devices
  • Loosen GenTL capability checks
General Changes
  • Installer behavior adapted for upgrade scenarios
  • added missing header in CVBpp.api
Several Modules
  • Patch update behavior influencing versioning introduced
  • Integrate the correct module dependency inheritance for SBOM
14.01.002 [2024-09-19T22:00:00Z]
  • Support directly downloading XML files from the device
GevTL.cti (1.26.11)
  • removed bootstrap register for RDMA
  • added a softer check for GEV version
GevSD.dll (2.17.6)
  • fix bug with cancelled wait and segment size filled accumulation
  • fix Incomplete reporting mechanism
CVFactory.dll (5.2.1)
  • Introduce heap optimization and fix node map lifetime
GenICam.vin (3.2.43)
  • fix chunk attachment for a specific scenario
cvbpy.api (1.11)
  • Added setter to the cvb.EnumerationNode.numeric_value property
  • Use Pyside6 starting from Python 3.11
CVUSBTL.cti (1.2.12)
  • Fix large payload transfer (equal size partitioned transfer)
CVGenApi.dll (3.4.2.9)
  • Prevent recursion for certain nodemap access functions
Several Modules
  • Integrate the correct license texts for SBOM
14.01.003 [2024-11-28T23:00:00Z]
SICalibration.json (unversioned)
  • fixed calibrator value for metric tutorial
CVBLicense.lib (2.6.0)
  • Improve GetBoardID Function in embedded platforms
CVMockTL.cti (1.3.12)
  • Take the descriptor size into the calculation while the resource contains a GenDC container
Setup.Lin.Camerasuite (unversioned)
  • moved font dependency out of the debian package
CVPixFmtCnv.dll (1.0.2)
  • enabled RGBA8 target conversion
CVUSBTL.cti (1.2.13)
  • Fix unexpected behavior of a test on aarch64 release
CVDeviceID.dll (1.0.1)
  • Fix DeviceList constructor not working on non-embedded devices
CVBNet.api (1.142.1)
  • Fix relative device paths being handled as access tokens
GevSD.dll (2.17.7)
  • Fixed socket memory on Linux
GenICam.vin (3.2.44)
  • Allow access of colors as 3rd dimension in RGB PFNC buffers
GevSD.dll (2.17.8)
  • fix endianness of buffer layout table buffer count entry
CVCDriver.dll (4.3.14)
  • fix no MAC address query other than GevTL
  • Prevent deadlock during special conditioned stream abort
GenICam.vin (3.2.45)
  • support switching RDMA off
CVBNet.api (1.142.2)
  • Fix certain LabeledRectOverlay properties not updating the text visualization
LicenseManager.exe (1.3.2.18)
  • new build for change in embedded licensing dependency
CVMgmtSvc.exe (2.19.3.24)
14.01.004 [2025-01-30T23:00:00Z]
GenICam.vin (3.2.48)
  • Sync for concurrently active waits not always executed
  • Support Teledyne Genie Nano M1280 Laser Profiler custom format
  • Fix 2.5D data conversion into 2D plane for depth maps
  • Fix support for BiColor PFNC formats
Qt (5.12.1)
  • Added basic QML in Linux installers
CVUSBTL.cti (1.2.15)
  • Optimized equal size transfer calculations
  • Adopt call to CVCDriver.dll for finding driver name
CVBNet.api (1.142.3)
  • Improve character check when opening an discovery access token
CVCDriver.dll (4.3.15)
  • Update license queries
GevTL.cti (1.26.12)
  • Change in call to driver find function from CVCDriver.dll
GevSD.dll (2.17.9)
  • Fix leader packet being ignored when no buffer present and blockID is newer than expected
14.01.005 [2025-04-08T22:00:00Z]
GevFD.dll (2.5.14)
  • Fix lost buffers in special occasions
CVMockTL.cti (1.3.14)
  • Prevent payload size overflow for large images
GenICamBrowser.exe (4.12.1) (In case of problems: Use 14.01.004 and contact support.)
  • Now using C++ API Stack
  • Fix snap behavior
FWUpdater.exe (2.2.0)
  • Add --devices option to list all devices and --model option to update the firmware of all devices with a given model (to be used in combination with --all)
TeachBench.exe (none)
  • Add missing WPF DLL
  • Fix bug on overlay classifying incorrectly on MouseUp
collect-camsuite.exe (1.5.2)
  • Update runtime version
GenICam.vin (3.2.49)
  • Add support for 3D mono data
  • Add flexible GenDC descriptor handling and dynamic VPAT creation for containers
  • Fix snap behavior for GenICamBrowser
CVBpp.api.Tutorials (1.0.1)
  • Refresh builds
GevTL.cti (1.26.13)
  • Respect device packet size before overriding
GevSD.dll (2.17.11)
  • Make buffer layout table register more fail safe
  • Support co-existence of multiple RDMA capable NDSPI providers
14.01.006 [2025-05-19T22:00:00Z]
GenICamBrowser.exe (4.12.2)
  • remove focus loss when setting IP
  • rework the save consecutive images functionality
CVUSBTL.cti (1.2.17)
  • removed event exceptions
  • no buffer info exceptions if not implemented
GevFD.dll (2.5.16)
  • fixed revoke active buffer
  • changed GenTL compliant error code
GevSD.dll (2.17.15)
  • removed memory region offset (RDMA streaming)
  • fix buffer layout table handling
  • fixed local port for RDMA
  • No buffer info exceptions if not implemented
GevTL.cti (1.26.15)
  • removed some internal event exceptions flooding debug output
  • prevent buffer info exceptions if not implemented
GenICam.vin (3.2.52)
  • allow single Flow GenDC no composite
  • improve GenDC buffer parsing for color formats
  • implement non blocking chunks configuration if node is not readable or not writable
Linux installer
  • fix installer script bug for ubuntu release detection
14.01.007 [2025-08-19T22:00:00Z]
Setup.Lin.Camerasuite (-)
  • Fixed Ubuntu version check (Ubuntu 22.x and newer) for installing font packages
EditBindings.exe (1.1.1)
  • Fix validate command line option being parsed incorrectly
GevTL.cti (1.26.16)
  • MAC endiness fix
GenICam.vin (3.2.55)
  • Fixed unloading logic
  • improved BGR alpha channel handling
  • improve VPAT cache for non GenDC streaming
  • Fix 90-degree rotation vin-stack option
GenICamBrowser.exe (4.12.6)
  • Fixed FW Updater path on Linux
  • Fixed MAC display and remove detached threads
  • Hide Splash screen early, get cvb path from environment and fix bandwidth calculation
GevSD.dll (2.17.17)
  • Filter corrupt packet
  • Reset segments size filled correctly
  • correctly initialized event registration for rdma
14.01.008 [2025-09-10T22:00:00Z]
GevTL.cti (1.26.17)
  • Fixed force IP (static IP configuration)
14.01.009 [2025-10-26T23:00:00Z]
GevFD.dll (2.5.18)
  • Change solutions and project files to variable Windows SDK/ WDK versioning
  • Fix failure to reopen device when multiple devices simultaneously disconnect
  • Fixed deadlock on early kill
GevTL.cti (1.16.19)
  • Fix race condition when reopening device in reconnect callback
GenICam.vin (3.2.57)
  • Fix undefined behaviour when stopping acquisition when using turbodrive
LicenseManager.exe (1.3.4)
  • Fix request license dialog not accepting emails when the domain name is longer than four letters
14.01.010 [2025-11-26T23:00:00Z]
GenICam.vin (3.2.58)
  • Make nodemap checks more flexible to incorrect implementations
GenICamBrowser.exe (4.12.7.64)
  • Detect device access mode correctly
cvu3v.sys (no version change)
  • adapt Windows 11 signature
14.01.011 [2026-01-14T23:00:00Z]
CVUAL.dll (1.14.8)
  • Fixed device enumeration for new inf DeviceGUID
15.00.000 [2025-10-23T22:00:00Z]
Major Release - please refer to the version 15.0 release notes for the list of changes.
15.00.001 [2025-12-17T23:00:00Z]
CVBpy (no version change)
  • Add VinBuffer as a member of the NodeMapID class
  • Constructor overloads have been placed in the regular method section in the API reference document
CVCDriver.dll (4.3.16)
  • Add internal CVMockTL discover when in access token
cvbpp.api (1.11.1)
  • Introduce a generic factory function to the DataType class
  • Fix failure to add gevserer node to category node
  • Add wrapper functions for chunk node serialization
  • Add correct utf8 conversion
GenICam.vin (3.4.5)
  • Make nodemap checks more flexible to non-standard implementations
cvu3v.sys (-)
  • Windows 11 signature
GevTL.cti (1.27.4)
CVCDriver.dll (4.7.1)
CVUSBTL.cti (1.3.1)
CVCImg.dll (4.19.4)
CVCFile.dll (4.6.12)
  • fix device ID query
CVGevServer.dll (3.10.4)
  • Fix chunk nodes unable to be updated whilst gevserver is running
  • Set correct length value for StringRegNode in nodemap XML
CVPixFmtCnv.dll (1.0.5)
  • Make CVPFCreateImageFromPFNCValue backward compatible
  • Let the PFNC value-based images return the effective bit size on the DataType function call
GevSD.dll (2.18.2)
  • Fix GevServer crash when sending test packet for packet size negotiation
CVUAL.dll (1.15.2.6)
  • Fix sending of GenCP packets larger than supported device packet size
  • add full utf8 character compatibility
GenICamBrowser.exe (4.13.1.9)
  • Check access status correctly
  • Fixed acess mode for correct display of IP setting dialog
FWUpdater.exe (2.2.3)
  • Support FW update for special USB devices
