I am using the following code to rotate an image by 180 degrees.
When I do, the width of the output image is 1 pixel less than the input image. Since this is a simple 180-degree rotation, I would expect the output to be the same width.
Can you suggest a mechanism to keep the image size constant or an alternative to the AffineTransform operation ?
Many Thanks
var angle = new Angle
Deg = 180
var matrix = new Matrix2D( angle);
var affineMatrix = new AffineMatrix2D(matrix, Point2Dd.Empty);
var rotateImage = CurrentImage.AffineTransform(affineMatrix);
CurrentImage?.Dispose();
CurrentImage = rotateImage;
As an alternative I have tried to set the driver to rotate the image by 180 degrees using the code below. This seems to have no effect. I have taken the values from the INI file and tried to set them in code.
What am I doing wrong? Is there some documentation that explains this? I have searched for “RotateImage” and that doesn’t return any results in the .NET API documentation.
which acquisition Stack are you using as parameter?
I assume you are using the GenTL here.
For now it seems like a bug in CVB, I will forward this information to have it fixed in one of the next releases.
As a workaround: AcquisitionStack::Vin should work.
Yes, I am using the GenTL stack. The reason for using this stack is so that I can identify individual corrupt frames which I can’t do using the vin stack.
I will stick with using the SubImage rotation after acquisition, but good to know why it wasn’t working trying to set in the driver.
