siLogSvc - An instance of this application / service is already running on this system
When starting /opt/cvb/bin/siLogSvc -s inside kubernetes using containerd we get this message
                  (c) 2015 STEMMER IMAGING GmbH
STEMMER IMAGING Logging Service Application
BuildDate : 	Jun  7 2019
An instance of this application / service is already running on this system.
However when running ps aux there is no other siLogSvc process running.
What is the method it used to determine if another instance of this process is already running? Have it created a pid file somewhere maybe?
Hi @jonta
we currently do not support containers like docker. This is related to our services we use with CVB including the siLogSvc. You could try to work without the CVB Log Service which is only used for logging. But you probably will get issues with the CVB Management Service which is needed for licensing.
If you need a solution within a container like docker this need to be done via a payed service. for that you can contact us directly.
Sorry for the issues you have and that I do not have a more pleasant answer.
I found out that the issue is when the root filesystem is not writable. For some reason it then gives an error that the service is already running and refuse to start it : )
Good news: We now have basic docker support for linux guests and usb licensed CVB. See more here.
