Hi, could you please remove sudo from install_cvb and uninstall_cvb shell scripts? This creates a huge incovenience when using containerized environment since containers don’t have sudo by default and usually don’t even need it.
Removing sudo before commands and instead using something like:
if test $? != 0
then
echo "[ERROR] Please run this file with sudo"
exit 1
fi
Would improve the install file usability in different environments.
Removing sudo within shell script and running the whole script with sudo (i.e. sudo ./install_cvb.sh) still gives the script root permissions so everything can be installed properly if sudo is needed
