Reading ChunkEncoderValue from AT C5
Hi! I’m trying to read ChunkEncoderValue node from AT C5-1280 using .NET API:
var device = DeviceFactory.Open("GenICam.vin");
var deviceModeMap = device.NodeMaps[NodeMapNames.Device];
CvbStream stream = device.Stream;
stream.Start();
    using (StreamImage image = stream.Wait())
        var encoderValues = new List<long>();
        var scanLineSelector = deviceModeMap["ChunkScanLineSelector"] as IntegerNode;
        for (var scanLine = scanLineSelector.Min; scanLine <= scanLineSelector.Max; scanLine += scanLineSelector.Increment)
            scanLineSelector.Value = scanLine;
            var encoderValueNode = deviceModeMap["ChunkEncoderValue"] as IntegerNode;
            encoderValues.Add(encoderValueNode.Value);
finally
    stream.Stop();
But accessing property encoderValueNode.Value throws error:
System.IO.IOException: 'IntegerNode[Std::ChunkEncoderValue]: Node is not readable.'
Why this node is not readable?
I can read this node using AT’s examples from cxSupportPackage with exactly the same camera settings.
I can read encoder value from chunk payload (Using Chunk Mode Data with CVB.NET). But I wanted to use vendor independed GenICam SFNC.
GenICam Browser is reading encoder values just fine. Seems like I’m missing something…
2021-04-26 13_22_57-GenICam Browser
Hi kokostek,
the transmission of chunk data needs to be enabled inside the GenICam.vin-driver to be available over the api.
Also the “Chunk Mode” needs to be activated over the camera NodeMap:
activateChunkMode
Than your code should be working.
Note that transmitting chunk data might have a negative inpact on the performance.
Hi Simon,
thanks a lot for your solution. It works fine (I didn’t test performance yet though).
I just want to add my two cents regarding using GenICam.vin driver. One can also set AttachChunk programmatically if she opens device using Discover. I myself prefer Discover option as it permits to select device using info like IP address, etc. (not just CVB channel number). Here is the example:
// Select device by serial number, IP address, etc...
// Selecting first device here to be short.
DiscoveryInformationList foundDevices = DeviceFactory.Discover();
var selectedDevice = foundDevices[0];
// Set CVB color format to "Raw".
// I suppose we need this when working with chunks.
selectedDevice.SetParameter("PixelFormat", "0");
// Turn on "Attach chunk" parameter, so that chunk
// nodes become readable.
selectedDevice.SetParameter("AttachChunk", "1");
// Open device and configure chunk mode.
var device = DeviceFactory.Open(selectedDevice);
var deviceNodeMap = device.NodeMaps[NodeMapNames.Device];
var chunkModeActive = deviceNodeMap["ChunkModeActive"] as IBooleanNode;
chunkModeActive.Value = true;
// Read encoder value(s) along with image.
stream.Start();
        var scanLineSelector = deviceNodeMap["ChunkScanLineSelector"] as IntegerNode;
            var encoderValueNode = deviceNodeMap["ChunkEncoderValue"] as IntegerNode;
finally
    stream.Stop();
Credit to this post for example of setting driver parameters.
