Random Crashes Whilst Using Minos
Hi @rtp_derahs,
Sure, the crash usually happens a couple of seconds after adding a model to the training set, however the timing up to that point is random…so its not always after the 5th model taught etc…
I have sent an update regarding the rotational error to the support team. It seems very odd but the following seems to have solved my problem, before I was using the ‘RBG To Mono’ tool within the TeachBench to convert the images to greyscale, this is when I was getting the errors. A colleague suggested using InfranView to batch convert our set of images to greyscale before bringing them into the TeachBench to save a bit of time, and the error hasn’t appeared since…definitely a weird one.
Okay, I can send the training set over to you, is there a preferred place you would like it or just over email? I will also create a crash dump of the application for you and send that to you as well.
Thanks for your support.
