Modifying individual PixelFormat settings for Dual streams of a Multispectral Camera
This works perfectly as long as the saving time is shorter than 1/fps. I.e. there are always buffers available.
The intention of FlowSetInfo is to give infos about size and alignment, i.e. memory stuff.
(We developed the Flows with external memory, like a GPU, in mind).
So not the number of “queued” buffers.
If you are using GigE you can access the Nodemap of the Datastream.
I will post a small snippet in the next post …
Or even simpler:
Number of Buffers in Pool = Number of Buffer - Numbers of Buffers you currently hold.
I’m not entirely certain this is compatible with the AcquistionStack::GenTL, but maybe it helps.
void getStreamInfos(const Cvb::Stream& stream)
  using S = Cvb::Driver::StreamInfo;
  // basic success
  aquired = getStatisticsInfo(stream, S::NumBuffersAcquired);
  delivered = getStatisticsInfo(stream, S::NumBuffersDelivered);
  // basic error
  lost = getStatisticsInfo(stream, S::NumBuffersLost);
  lostTransfer = getStatisticsInfo(stream, S::NumBuffersLostTransfer);
  lostLocked = getStatisticsInfo(stream, S::NumBuffersLostLocked);
  // usually gev issues
  corruptArrival = getStatisticsInfo(stream, S::NumBuffersCorruptOnArrival);
  corruptDelivery = getStatisticsInfo(stream, S::NumBuffersCorruptOnDelivery);
  // advanced generic info
  locked = getStatisticsInfo(stream, S::NumBuffersLocked);
  pending = getStatisticsInfo(stream, S::NumBuffersPending);
  beingFilled = getStatisticsInfo(stream, S::NumBuffersBeingFilled);
  announced = getStatisticsInfo(stream, S::NumBuffersAnnounced);
  queued = getStatisticsInfo(stream, S::NumBuffersQueued);
  // gev package info
  packages = getStatisticsInfo(stream, S::NumPacketsReceived);
  resendPackages = getStatisticsInfo(stream, S::NumResends);
  // err ... no clue
  triggerLost = getStatisticsInfo(stream, S::NumTriggersLost);
inline uint64_t getStatisticsInfo(const Cvb::Stream& stream, Cvb::Driver::StreamInfo info)
    return stream.Statistics<uint64_t>(info);
  catch (std::exception e)
    std::cerr << "failed to get info about (as number): " << static_cast<int>(info) << ". Reason: " << e.what() << std::endl;
  catch (...)
    std::cerr << "failed to get info about (as number): " << static_cast<int>(info) << ". Reason: catch(...)" << std::endl;
  return ~uint64_t(0); // i.e. max value is error or not available
