is there a way to return a List of Points to a Pointcloud?
I would like to loop through all Points, do something and afterwards return it to a Pointcloud.
Hi @Michael,
there is no direct way of doing this.
What you can do is get the points of a PointCloud via TryEnumeratePointsAs, modify the point list in whatever way you desire, then create a new PointCloud with the same amount of points in your modified points list and then use the PointComponents to iterate over each point in the new PointCloud and set the value of the point in your list.
Cheers,
Tim
We had a similar question couple of weeks ago:
https://forum.commonvisionblox.com/t/how-to-create-a-point-cloud-manually-from-3d-points/901
Maybe that helps…
No yet,
I think it would be good to have this as a constructor parameter.
