Linear Access to the image data
This access is available on the ImagePlane, e.g. to access the first plane:
LinearAccessData imageData = image.Planes[0].GetLinearAccess();
This gives you the BasePtr, XInc, and YInc as IntPtrs. This call will throw if linear access is not possible, though. To get around that you can call:
image.Planes[0].TryGetLinearAccess(out LinearAccessData imageData);
This does not throw, but returns false if not possible. You then have to use:
image.Planes[0].Vpat
By the way: if you know the pixel datatype upfront you can also use (for byte pixels):
LinearAccessData<byte> imageData = image.Planes[0].GetLinearAccess<byte>();
Additionally to the base pointer and increments you get an indexer to access the pixel data:
imageData[x, y] = 255 - imageData[x, y];
(This is convenient, but direct pointer access is faster.)
