I am acquiring data from a Camera and following the tutorial provided: Getting Started with CVB.Net , it is trivial.
var device = LoadCameraDriver();
device.Stream.RingBuffer.ChangeCount(NUM_DRIVER_BUFFERS, DeviceUpdateMode.UpdateDeviceImage);
Stream stream = device.Stream;
stream .RingBuffer.LockMode = RingBufferLockMode.On;
stream .Start();
using (StreamImage image = await stream.WaitAsync())
Process(image);
stream.stop()
However after acquiring the image, I would like to process the image and to access to the image data linearly.
In my previous implementation with the C-style AI I used the method:
cvbbool_t GetLinearAccess ( IMG Img,
cvbdim_t Plane,
void ** ppBaseAddress,
intptr_t * pXInc,
intptr_t * pYInc
I read the .Net API documentation but I couldn’t find a similar function for this purpose.
parsd
December 19, 2017, 3:36pm
2
This access is available on the ImagePlane, e.g. to access the first plane:
LinearAccessData imageData = image.Planes[0].GetLinearAccess();
This gives you the BasePtr, XInc, and YInc as IntPtrs. This call will throw if linear access is not possible, though. To get around that you can call:
image.Planes[0].TryGetLinearAccess(out LinearAccessData imageData);
This does not throw, but returns false if not possible. You then have to use:
image.Planes[0].Vpat
By the way: if you know the pixel datatype upfront you can also use (for byte pixels):
LinearAccessData<byte> imageData = image.Planes[0].GetLinearAccess<byte>();
Additionally to the base pointer and increments you get an indexer to access the pixel data:
imageData[x, y] = 255 - imageData[x, y];
(This is convenient, but direct pointer access is faster.)
gajus
April 29, 2021, 2:12pm
3
I there also an equivalent Python function for GetLinearAccess?
Thanks
The GetLInearAccess functions and the objects they return rely heavily on pointer arithmetics - a concept that is not commonly used in Python and therefore not very widespread - and at the same time dangerous if not used properly as it is extremely easy to create hard-to-debug problems with it. For those reasons the linear access functions were never mapped in CVBpy.
Instead we rely on numpy arrays: The method cvb.asArray will generate a numpy view on a image’s pixel data (without actually copying the data) and thereby provide simple access to the pixel data in an entirely pythonic way.
If you’re interested @Andreas has written a small post about that a while ago that might be worth looking at: https://forum.commonvisionblox.com/t/getting-started-with-cvbpy/241/9
