ISO Odroid XU4 with CVB
I found here that you provide the iso with Common Vision Blox for the odroid platform, but where can I download it?
Hi @pare,
sadly this information (the document) is rather old.
The Image you are talking about is no longer created/provided.
(It simply didn’t make sense to create images for a whole list of devices)
However getting CVB to work on Odroid is easy:
  1. Download Ubuntu from https://wiki.odroid.com/getting_started/os_installation_guide#tab__odroid-xu4
  2. Flash it on your Card
  3. Install Cvb from Common Vision Blox for 32 Bit Linux (the second list contains the arm images) (the package will contain a .sh installer)
Hope this helps.
Ok, perfect, thank you.
One thing to point out is that the approach by @c.hartmann will yield no less than the downloadable ODroid image did (it was, after all, just an Ubuntu downloaded from Hardkernel and a suitable - but by now slightly outdate - CVB version installed on it).
