I’m trying to grab an image using the Python API of CVB and I’m relatively new to Python. So my code below grabs 11 images and views the last one. It works so far… only once:
Afterwards the following error appears:
RuntimeError: failed to start acquisition with G2Grab
So what is happening? My guess is that my device is still open after the first run…
import os
import matplotlib.pyplot as plt
path = "%CVB%/Drivers/GenICam.vin"
path_exp = os.path.expandvars(path)
device = cvb.DeviceFactory.open(path_exp)
stream = device.stream
for x in range(0,10):
[img, status] = stream.wait_for(3000) #we just need the last image
stream.stop()
matImg = cvb.as_array(img)
plt.imshow(matImg.transpose(), cmap="gray")
Mmh, maybe Spyder runs the script inside its process.
You could del the device and stream to unload the driver (both must be deleted):
import os
path = os.path.expandvars('%CVB%Drivers/GenICam.vin')
device = cvb.DeviceFactory.open(path)
stream.stop()
del stream
del device
Alternatively you can also use the with statement:
import os
PATH = os.path.expandvars('%cvb%drivers/genicam.vin')
with cvb.DeviceFactory.open(PATH) as device, device.stream as stream:
IMAGES = [stream.wait()[0] for i in range(0, 10)]
stream.stop()
LAST_IMAGE = IMAGES[-1]
MAT_IMAGE = cvb.as_array(LAST_IMAGE).transpose()
plt.imshow(MAT_IMAGE, cmap='gray')
