I am using a IDS camera. I have installed the camera driver as well as the cvb camera driver. Everything should work fine. When I do the following task. everything works:
import cvb import os import numpy as np import matplotlib.pyplot as plt
first, there is nothing wrong with your code that is the intended way to use it!
However, crashing the kernel is clearly a bug on our side! As there have been recent changes to CVBpy this might have been fixed. I just checked with my current version and it works fine.
My current version will be available as nightly setup tomorrow!
If the error persists please contact support@stemmer-imaging.de and tell us:
OS Version and architecture
current CVBpy version (includes also dynamic information)
cvb.version()
CVuEye.vin version.
Furthermore you may check with a different device type like “%CVB%\Tutorial\ClassicSwitch.emu”.
