Help with Movie2
I’ve been going through each CVB.Net tools but I can’t figure out how to use Movie2, can someone explain how to get it to work? thanks
Hi Adam, see this for a short example:
void Main()
	// load device
	using(var device = Stemmer.Cvb.DeviceFactory.Open("GenICam.vin"))
		string fileName = "TestVideo.avi";
		var stream = device.Stream;
			// create recorder object
			using(var recorder = new Stemmer.Cvb.Movie2.Recorder(fileName, device.DeviceImage.Size, RecorderPixelFormat.Mono))
			 	// start acquisition of images
				stream.Start();
				// acquire 10 images and save to video file
				for(int i = 0; i < 10; i++)
					var img = stream.WaitFor(TimeSpan.FromSeconds(3));
					recorder.Write(img);
		catch
			// delete file if error occured
			if(File.Exists(fileName))
				File.Delete(fileName);
		finally
			// stop stream
			if(stream.IsRunning)
				stream.Abort();
Hope this helps.
If you have any more questions feel free to ask.
Cheers,
Tim
Thanks Tim! I’m wondering if its possible to display a camera stream in a VS forms display and also save the video at the same time? I’ve been trying this for a few hours but i can’t get it to work. Using streamHandler or not, either is fine
Hi Adam,
you should be able to just set the image after aquiring it.
display.Image = img;
It is best to use this in conjunction with WaitForAsync instead of WaitFor, to keep the UI fluid.
Cheers,
Tim
