Create a cvb.Image object from a numpy array
is it possible to convert a numpy array to a cvb.Image object? I didn’t find any function to do this. Just found this https://ftp.commonvisionblox.com/webdavs/forum/documents/CVBInterop%201.1.0.pdf, which is unfortunately not helping for the python case.
Thanks for your help!
Hi @JRo85 !
Yes it is! Just try the following:
import numpy as np
any_array = np.ones([2,2]) # 2x2 image of ones
cvb_image = cvb.WrappedImage.from_buffer(any_array)
# continue with cvb_image
Hope this helps. For fruther guidance you could look at Getting-Started-With-CVBpy
