Configure camera with GenApi
I try to used the CVB.NET SDK with my ImperX camera.
I am not able to read and write the camera parameters with the following code given in “Getting started with CVB.Net”…
The function “Device.NodeMaps(NodeMapNames.Device)” does not work for me.
I do not see where the problem is…
Thanks in advance,
Nicolas
    Dim _Device As Device = DeviceFactory.Open(foundDevices(1))
    If _Device.NodeMaps.Count > 0 Then
                Dim deviceNodeMap As GenApi.NodeMap = _Device.NodeMaps(NodeMapNames.System)
    End if
Hello @Davy54, what error do you get?
And also you say that NodeMapNames.Device is not working, yet in your code you use NodeMapNames.System.
