Can not readable visualization image of ShapeFinder2
here is my shape finder test project and img test result
WindowsFormsApp1.zip (15.2 KB)
Hello @sbphsho
we do not recommend training the SF classifier in your own application.
Can you try to use the “SF2Teach” program, which can be found in %cvb%Tutorial\ShapeFinder\VB.NET\SF2TeachNET\bin
Then load the created classifier in your test application and check if the visualization image is correct.
Cheers,
Tim
According to your instructions, I obtained a very strange image.
here is my sf2 file
wally.zip (34.0 KB)
I am an automation equipment engineer, and my current project requirement is to establish multiple image shape model and integrate them into recipe system of my program. It would be quite inconvenient if I couldn’t train shape model in my own program. Is the functionality of the CVB.Net version of ShapeFind currently incomplete?
Hi @sbphsho
have you tried the chapters here:
https://help.commonvisionblox.com/ShapeFinder/html_shapefinder2tutorial.htm
Hello @sbphsho
I can confirm that we validated this behaviour and see the same here.
We will investigate this bug and I will give you any new information we have on this issue.
Cheers,
Tim
Looking at the accumulator view when using ShapeFinder2 will not yield any actionable insights (the accumulator is effectively a ShapeFinder(1) entity).
